Hi all,
First post so please forgive me if it's in the wrong place. I have a small problem with inter vlanning on my a5500.
It may largely be lack of knowledge so any help would be greatly appreciated.
In short, my scenario is that I have a fully working network using a single A5500 as the only switch and gateway.
We have a a few vlans, for easy explaining let's call them "100" and "200".
The problem we have is that devices attached to these vlans can ping devices on the other vlans. They can also use windows explorer to browse to them with credentials, although granted the user would need to know the ip of the other device and the credentials.
I believe they can talk to each other because the A5500 is allowing inter vlan traffic.
My question is, can this be prevented so they cannot talk to each other at all? They would obviously still need to use the A5500 as the gateway.
I hope that makes sense and is clear enough.
Thank you.
#disable#a5500#Prevent#Inter-vlans
