I asked that because I noticed that since R2221P08 a new feature was introduced: "Disabling SSL 3.0", it allows to disable SSL 3.0 on the Switch to enhance security (clearly peer devices - Web Browsers in our case - should support TLS 1.0).
The explanation given on Release Notes was:
This feature allows you to disable SSL 3.0 on a device to enhance system security.
- An SSL server supports only TLS 1.0 after SSL 3.0 is disabled.
- An SSL client always uses SSL 3.0 if SSL 3.0 is specified for the client policy, whether you
disable SSL 3.0 or not.
To ensure successful establishment of an SSL connection, do not disable SSL 3.0 on a device when the peer device only supports SSL 3.0. HP recommends upgrading the peer device to support TLS 1.0 to improve security.
The system-view command is ssl version ssl3.0 disable (undo to revert to SSL 3.0, which is enabled by default).
