All IPv6 stuff happens over Vlan251... Here is the switch config:
login as: omitted
omitted@omitted's password:
* Copyright (c) 2010-2011 Hewlett-Packard Development Company, L.P. *
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<downtown-switch>system-view
System View: return to User View with Ctrl+Z.
[downtown-switch]display current-co
[downtown-switch]display current-configuration
version 5.20.99, Release 5101P01
sysname downtown-switch
clock timezone MST minus 07:00:00
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
domain default enable system
ipv6
telnet server enable
undo ip http enable
vlan 1
vlan 240 to 241
vlan 250 to 251
vlan 260
vlan 310
vlan 410
vlan 655
radius scheme system
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
local-user omitted
password simple omitted
authorization-attribute level 3
service-type ssh
interface NULL0
interface Vlan-interface1
ip address dhcp-alloc client-identifier mac Vlan-interface1
interface Vlan-interface240
interface Vlan-interface241
interface Vlan-interface250
description management network
interface Vlan-interface251
description Public and Management
ip address omitted 255.255.255.0
interface Vlan-interface260
interface Vlan-interface310
interface GigabitEthernet1/0/1
port link-mode bridge
description Link to FRT
port link-type trunk
port trunk permit vlan 1 107 240 to 241 250 to 251 260 310 to 311 410 to 411
port trunk pvid vlan 241
interface GigabitEthernet1/0/2
description Link to MikroTik
port trunk permit vlan 1 240 to 241 250 to 251 260 310 to 311 410 to 411
port trunk pvid vlan 250
interface GigabitEthernet1/0/3
port access vlan 251
interface GigabitEthernet1/0/4
description Link to SF UBNT
port trunk pvid vlan 251
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
port access vlan 250
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface M-GigabitEthernet0/0/0
interface Ten-GigabitEthernet1/0/29
interface Ten-GigabitEthernet1/0/30
snmp-agent
snmp-agent local-engineid 800063A203D07E28347701
snmp-agent community read omitted
snmp-agent sys-info version v2c v3
ntp-service unicast-server omitted
ssh server enable
arp timer aging 2
load xml-configuration
load tr069-configuration
user-interface aux 0
user-interface vty 0 15
authentication-mode scheme
user privilege level 3
protocol inbound ssh
return
