Just wanted to touch base with this issue. I figured out what I was doing wrong. I finally was able to get into the WebUI purely by fumbling around in the console CLI. Once I got into the WebUI i was able to play around with the permitable options. I have attached the settings I believe I need to configure an access port on interface gi1/0/1 and a trunk port with specific vlans setup on gi 1/0/2 (again, this is just for anyone that cares).
vlan 6
description Test VLAN
protocol-vlan 0 ipv4
ip-subnet-vlan 0 ip 192.168.6.0 255.255.255.0
vlan 10
Description Test VLAN 10
ip-subnet-vlan 0 ip 192.168.10.0 255.255.255.0
vlan 100
description Test VLAN 100
ip-subnet-vlan 0 ip 192.168.100.0 255.255.255.0
vlan 200
description Test VLAN 200
ip-subnet-vlan 0 ip 192.168.200.0 255.255.255.0
interface Vlan-interface6
ip address 192.168.6.1 255.255.255.0
interface Vlan-interface10
ip address 192.168.10.1 255.255.255.0
interface Vlan-interface100
ip address 192.168.100.1 255.255.255.0
interface Vlan-interface200
interface GigabitEthernet1/0/1
description Access Port Example Configuration
port link-mode bridge
port access vlan 10
interface GigabitEthernet1/0/2
description Trunk Port Example Configuration
port link-type trunk
port trunk permit vlan 1 6 100 200
So basically what happened, was I somehow was able to stumble through the Fundamentals Guide to turn on the http service. From there I configured the VLAN settings under the "Network" context menu on the left. I configured VLAN and VLAN interfaces. Once I configured that information as needed, I did a "display current" from system-view and saw my output. This makes a bit more sense to me now.
I am having some issues setting up HTTPS and SSH though. If anyone has a better tutorial then the one listed in the Fundamentals Guide, I would appreciate the link.
Thanks and I hope this helps someone!
