A800 Unable to see APs
  • 1.  A800 Unable to see APs
    Posted Sep 11, 2013 03:55 AM
    I've got an A800 controller with several AP61's connected but the controller is unable to see any of the APs.
    I've erased the system (write erase all) plugged a brand new AP61 but that also isn't recognised.
    Below is some controller info with the system log.
    (Aruba800) #show version
    ArubaOS (MODEL: Aruba800), Version 3.3.2.18
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2009, Aruba Networks, Inc.
    Compiled on 2009-07-07 at 11:43:14 PDT (build 21791) by p4build
    ROM: System Bootstrap, Version CPBoot 1.1.4 (May 18 2004 - 15:45:14)
    Switch uptime is 4 minutes 39 seconds
    Reboot Cause: User reboot.
    Supervisor Card
    Processor  16.20 (pvr 8081 1014) with 256M bytes of memory.
    32K bytes of non-volatile configuration memory.
    256M bytes of Supervisor Card System flash (model=CF 256MB).
    (Aruba800) #
    (Aruba800) #show log system all
    Sep 10 21:47:34 :315382:  <CRIT> |fpapps|  Reboot Cause: User reboot.
    Sep 10 21:47:38  KERNEL: klogd started: BusyBox v0.60.4 (2009.07.07-18:33+0000)
    Sep 10 21:47:38  KERNEL: Aruba Networks Model A8xx
    Sep 10 21:47:38  KERNEL: ArubaOS Version 3.3.2.18 (build 21791 / label #21791)
    Sep 10 21:47:38  KERNEL: Built by p4build@trinidad on 2009-07-07 at 11:43:14 PDT (gcc version 3.4.1)
    Sep 10 21:47:38  KERNEL: Copyright (c) 2002-2009, Aruba Networks, Inc.
    Sep 10 21:47:38  KERNEL: i2c-dev.o: Registered 'System I2C Interface' as minor 0
    Sep 10 21:47:38  KERNEL: VFS: Disk change detected on device ide0(3,3)
    Sep 10 21:47:41 :399816:  <ERRS> |fpapps|  Initializing the Line Card for Cabernet 1
    Sep 10 21:47:41 :399816:  <ERRS> |fpapps|  Initializing the  Cabernet STD Port Callbacks
    Sep 10 21:48:27 :399801:  <ERRS> |cts|  An internal system error has occurred at file sapi.c function sapi_rsp line 247.
    Sep 10 21:48:52 :304001:  <ERRS> |stm|  Unexpected stm (Station managment) runtime error at data_path_handler, 547, data_path_handler: recv - Network is down
    (Aruba800) #
    Any help would be much appreciated.
  • 2.  RE: A800 Unable to see APs
    Posted Sep 11, 2013 05:25 AM
    Hi Blee,
    Are your APs getting an IP address via DHCP?
    Is your controller configured with an IP address in the same subnet as the DHCP scope above?
    Here's a little info about how your APs will try to find the controller....
    Your AP61s will use the following methods to try to find your controller:
    1.  DHCP option (43)
    2.  ADP
    3.  DNS (aruba-master)
    Here's a great  troubleshooting guide which might help: http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Why-Doesn-t-My-Aruba-Access-Point-Find-My-Controller-Part-1-7-05/td-p/18906
  • 3.  RE: A800 Unable to see APs
    Posted Sep 17, 2013 02:58 AM
    Sorry for the delay in replying.
    Yeah totally overlooked the obvious and now sorted my DHCP issue and the APs can see the controller. Also made a custom Y cable which came in handy for troubleshooting.
    Thanks both for your help.
  • 4.  RE: A800 Unable to see APs
    Posted Sep 11, 2013 09:00 PM
    If you have console access to the AP61 you could watch it boot... it would be the best way to see 'how far' in the process it gets.
    JF
