AAA 802.1x for the AP itself possible?
  • 1.  AAA 802.1x for the AP itself possible?
    Posted May 21, 2014 07:55 AM
    it is an requirement, that the AP itself makes a 802.1x authentication on the connected switchport (TLS with client cert or TTLS with username/password).
    Is that possible and how? (for IAP or CAP). I hope my question is clear to understand (this is not for client athentication).
    Best regards
    Jens
  • 2.  RE: AAA 802.1x for the AP itself possible?
    Posted May 21, 2014 07:57 AM
    I don't believe Instant currently has an 802.1X supplicant.
    For a campus AP, you enter 802.1X credentials on the provisioning screen under "802.1X Parameters using PEAP". Currently only PEAP is supported.
    (master) (config) #provision-ap
    (master) (AP provisioning) # apdot1x-username <username>
    (master) (AP provisioning) # apdot1x-passwd <password>
  • 3.  RE: AAA 802.1x for the AP itself possible?
    Posted May 21, 2014 08:22 AM
    Thank you very much. That was fast!
    Best regards
    Jens
