Wired Intelligent Edge
aaa authentication for local users - 2930F switches
  • 1.  aaa authentication for local users - 2930F switches
    Posted Jul 09, 2020 11:29 PM
    What is an equivalent command - aaa authentication allow-fail-through for 2930F Aruba switches?
    I want to tell the 2930F switch - Use first local configured user credentials. If this fails then use the radius server.
    Thanks.
  • 2.  RE: aaa authentication for local users - 2930F switches
  • 3.  RE: aaa authentication for local users - 2930F switches
    Posted Jul 14, 2020 04:59 AM
    I don't think you can set the order, radius or TACACS will be first, local can be set as a backup. You could have your partner or Aruba SE file an enhancement request in the Aruba Innovation Zone.
  • 4.  RE: aaa authentication for local users - 2930F switches
    Posted Jul 17, 2020 03:18 AM
    That's right there is no facility in 2930F devices to set order. I think this has been rectified in CX switches.
    I don't get it, what you mean - You could have your partner or Aruba SE file an enhancement request in the Aruba Innovation Zone.
    What's the Aruba innovation zone?
    Thanks.
  • 5.  RE: aaa authentication for local users - 2930F switches
    Posted Jul 17, 2020 03:51 AM
    Innovation Zone is a system where Aruba Partners, Resellers and Distributors as well Aruba employees have access to.
    You can reach out to your partner/reseller or if you have direct contacts with the local sales team of Aruba in your region reach out to them so they can file a feature enhancement request.
  • 6.  RE: aaa authentication for local users - 2930F switches
    Posted Jul 17, 2020 03:54 AM
    Got it.
    Thank you.
  • 7.  RE: aaa authentication for local users - 2930F switches
    MVP GURU
    Posted Jul 18, 2020 04:37 AM
    Yes, it is not supported on ArubaOS switch but there is the option now on ArubaCX Switch
    for IAP, it is enable by default (and for Aruba Controller, there is a settings for this)
