Network Management
AAA port-access authentication slow
  • 1.  AAA port-access authentication slow
    Posted Dec 30, 2022 04:43 PM
    I have AAA port-access authentication enabled on the ports.  We also use Duo MFA so that after the user logs into Windows, they also get the push notification from Duo app.  I found out that they only get the Duo push sometimes on ports that have AAA enabled.
    Also, sometimes the computer shows no LAN connection after login, but after a few seconds it gets connection, all on AAA ports.
    Any idea why?  I'm assuming because it takes longer to authenticate with RADIUS server?
  • 2.  RE: AAA port-access authentication slow
    Posted Jan 04, 2023 01:50 PM
    Any idea anyone?
  • 3.  RE: AAA port-access authentication slow
    Posted Jan 05, 2023 07:00 AM
    You would need to find out what actually happens, how the computer and/or user are authenticated, when these authenticated, etc. If it doesn't work properly there may  be no authentication, failing authentication, VLAN change between authentications or authenticated/non-authenticated, no DHCP after (re)authentication, and many more possibilities.
    Your Aruba partner who implemented this, or Aruba Support may be helpful to get this analyzed and resolved.
