Atmosphere 2021
last person joined: 9 days ago
AAA removal from 2930F Switchport
  • 1.  AAA removal from 2930F Switchport
    Posted May 16, 2023 10:45 AM
    I just have one small issue. I have Radius auth working for switch ports using the following commands for port 19:
        aaa port-access authenticator 19
        aaa port-access authenticator 19 client-limit 4
        aaa port-access mac-based 19
        aaa port-access mac-based 19 addr-limit 32
        aaa port-access 19 critical-auth voice-vlan
        aaa port-access 19 critical-auth data-vlan
        aaa port-access 19 auth-priority mac-based authenticator
        aaa port-access 19 auth-order authenticator mac-based
    However, if I want to remove the configs all are successfully being removed except:
    Can you please let me know how to remove? Is it that it can't be removed?
    Everything works, its just when I run command: show run int 19, I still see aaa port-access mac-based 19 addr-limit 32 under the port config.
    Any assistance would be greatly appreciated.
  • 2.  RE: AAA removal from 2930F Switchport
    Posted May 17, 2023 01:43 PM
    Check here for an explanation. If you set the addr-limit to the default value of 1, it will disappear from the configuration.
  • 3.  RE: AAA removal from 2930F Switchport
    Posted May 18, 2023 04:54 PM
    Thanks Herman, this did the trick.
    Do you have a link to Wired/Switching forum?
  • 4.  RE: AAA removal from 2930F Switchport
    Posted May 25, 2023 12:18 PM
    Wired Intelligent Edge is here.
  • 5.  RE: AAA removal from 2930F Switchport
    Posted May 17, 2023 01:44 PM
    Please post such a question in the Wired/Switching forum, it has nothing to do with Atmosphere 2021.
    Check here for an answer.
