  • 1.  AAA server test from Controller
    Posted Feb 08, 2023 12:19 AM
    Hi All,
             While verifying AAA server test in controller, I didn't configure this password in controller. Is the password is already configured in clear pass server and I'm using the same password while connecting WLAN client. how these password concept works between controller, clear pass server and client?
  • 2.  RE: AAA server test from Controller
    Posted Feb 08, 2023 12:49 AM
    no the password is not configured by default in ClearPass.
    basically the aim of this command is to test Radius auth connectivity to the radius server.
    for sure  you can add a your test user creds to the local db in ClearPass
  • 3.  RE: AAA server test from Controller
    Posted Feb 08, 2023 01:01 AM
    Is it mandatory to configure password in clearpass local database when verifying aaa test from controller.?
  • 4.  RE: AAA server test from Controller
    Posted Feb 08, 2023 01:29 AM
    no it is not mandatory.
    when you are troubleshooting connectivity, all you want to know is if the Radius packets are reaching clerarpass.
    with the test aaa command, you can see the request in access tracker, that shows there is connectivity and radius secret key is correct, irrespective of whether the auth is successful or not
