Wired Intelligent Edge
AAA/NAC Comware v7 Feedback
  • 1.  AAA/NAC Comware v7 Feedback
    Posted Oct 24, 2016 07:48 AM
    Here some feedbacks with AAA/NAC features on Comware V7 (5130/5510HI/etc..)
    Hope it will help !
    Serge
    Attachment(s)
  • 2.  RE: AAA/NAC Comware v7 Feedback
    Posted Dec 07, 2016 04:17 AM
    Hello Serge,
    On page 15 there is a diagram with all the features.
    I have 5510 switches and 5400. And for the 5400 i also use dynamic ACL.
    On this page it says that on the 5130 and 5510 also dynamic ACL are supported.
    Do you have an example of how to do this in clearpass for the 5510.
    Already my thanks.
  • 3.  RE: AAA/NAC Comware v7 Feedback
    Posted Dec 07, 2016 06:09 AM
    You should use the standard Radius « Filter-Id » Attribute (11)
    And define the value as the ACL number you want to apply on the authenticated port.
    Or
    Use the user-profile feature. In the case, set user-profile name as standard Radius Filter-id attribute (11)
    User-profile test
         qos apply policy test inbound
    acl number 3000
     rule 0 permit tcp source-port eq 21
    traffic classifier classifier_1
    if-match acl 3000
    traffic behavior behavior_1
     filter deny
    qos policy test
      classifier classifier_1 behavior behavior_1
    User-profile test enable
    Regards
  • 4.  RE: AAA/NAC Comware v7 Feedback
    Posted Dec 07, 2016 08:15 AM
    Thanks for the quick replay,
    I will test it.
    Good document by the way.
    Keep it coming
