a/b/g/n on Same AP
  • 1.  a/b/g/n on Same AP
    Posted Dec 27, 2013 01:57 PM
    I have the following questions :
    1-  What is difference between  "dual band "  &  "dual radio "  ?
    2 - Can  AP-93   have some users connected using  802.11b while others connected using   802.11g ?
    2 - Can  AP-105  have some users connected using  802.11b while others connected using   802.11g ?
  • 2.  RE: a/b/g/n on Same AP
    Posted Dec 27, 2013 01:59 PM
    1) Dual-band means the radio is capable of operating in either the 2.4 or 5 GHz space (only one can be active). Dual-radio means the AP has two radios and can operate in both bands at the same time.
    2 / 3) Yes, but remember that older devices will "slow down" newer devices because they take up more airtime for everyone.
  • 3.  RE: a/b/g/n on Same AP
    Posted Dec 27, 2013 02:54 PM
    Thx
    For 2/3 ,   only will slow down Others  , or  all users will be forced to use the same  .11 Technology ( slowest one )  ?
  • 4.  RE: a/b/g/n on Same AP
    Posted Dec 27, 2013 02:56 PM
    Since 802.11b transmissions eat up more airtime, all devices may experience slower speeds when b devices are active.
  • 5.  RE: a/b/g/n on Same AP
    Posted Dec 27, 2013 03:16 PM
    Thx
    what do you mean by Eat Up More Air Time ?
  • 6.  RE: a/b/g/n on Same AP
    Posted Dec 27, 2013 03:17 PM
    802.11b devices take much longer than an 802.11g device to send the same amount of data. So while the b device is trying to send or receive that chunk, the g device has to wait.
