Ability to report on RAP Tunnel Downtime/Uptime.
  • 1.  Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 11, 2012 02:35 PM
    I was looking for a way to get a detailed report or output or something that can show me for example the following:
    Need to be able to see the device events for a particular RAP pertaining specifically to the AP GRE tunnel uptime vs downtime for a specified amount of time (e.g. 2 weeks ago until today)
    The device uptime report does not seem to go into detail of every occasion the AP goes offline/online. Like a line by line item.
    Is this possible?
    Can I generate this by hand somewhere else, through logs? The syslogs & traps shows some information but not all.
    Any help on this is greatly appreciated...
  • 2.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 11, 2012 02:54 PM
    Does a notification for email works for you or you need a report report of it?
  • 3.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 11, 2012 03:41 PM
    Unfortunately, I need some sort of report to be produced.
    I need something that can show me a line by line item report of when the AP bootstrapped or rebooted or went offline, any of the 3.
    if I report on a specific AP, and I know the AP went offline 10 times in the last week, if I run this report, I would see 10 line items for the week
  • 4.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 12, 2012 11:52 AM
    I opened a TAC case and for this and they advised me that this feature does not exist and I should request a feature request.
    I will do that as soon as they fix my partner account, I cannot seem to access that section anymore.
    Currently Airwave can only do the Device Uptime Report.
    TAC's Response:
    Currently the option which we have on Airwave would be device uptime report(which you already know). In that when we run a report for “Downtime For Aruba Thin APs” we get the downtime for the device however, it shows only the duration for how long the APs were down.
    Bummer...
  • 5.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 12, 2012 11:53 AM
    Thank you very much for sharing the information with the community!
    Cheers
    Carlos
  • 6.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 12, 2012 11:59 AM
    Not a problem.
    Once I post the feature request, I will share it on this thread.
    EDIT: I also discovered that the Device Events table that you see at the bottom of a particular device within AMP can only store 2Mbytes worth of information, after that it gets wiped out.
    Good to know as if you are trying to see events from 3 weeks ago, you might not have them if there are too many events for that particular device.
  • 7.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 13, 2012 04:39 PM
    Reporting for RAP Tunnel up/downtime is not currently possible within AMP.  There's currently no SNMP MIB or trap or event/syslog message that relays information of the GRE tunnel status to AMP.  Be sure to file this in the Ideas Portal on the support website.
  • 8.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Dec 14, 2012 08:22 AM
    Will do.
    My partner account for some reason disabled my access to the ideas portal. Case opened to have it fixed.
  • 9.  RE: Ability to report on RAP Tunnel Downtime/Uptime.
    Posted Jan 03, 2013 07:43 AM
    Just posted the idea on the portal guys.
    https://arubanetworkskb.secure.force.com/prm/ideas/viewIdea.apexp?id=08740000000LBw3
    Feel free to promote if you find useful
