About Aruba ClearPass Guest configure ,Please Help me , Thanks!
  • 1.  About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 08, 2013 07:32 AM
    I amm a  beginner of Aruba Network ,I want to configure Guest Network and Self-register , But I don't have this information;
  • 2.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 08, 2013 07:51 AM
    Do you have an instant ap or a controller ?
    Are you trying to use the internal captive portal or clearpass guest ?
  • 3.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 08, 2013 07:57 AM
    I use a  (CPPM) Devices of clearpass Guest , it is OS 6.2;
    The environment have a Wireless Controller and Wireless AP,I want to use CPPM for guest System,Implement employee registration;
  • 4.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
  • 5.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 08, 2013 09:41 AM
    The First , Thank your help ! But I use a CISCO Wireless Controller, I don't know how to set some attributes, don't know whether there is such a test configuration;
  • 6.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 08, 2013 10:44 AM
    Start here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=6454
    This document above has the Cisco side of the configuration, but the Amigopod Configuration is deprecated and should be ignored.
    The ClearPass Guest side should be taken from here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11900
  • 7.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 09, 2013 08:45 AM
    Today, I try to set up the Clearpass Guest; I have to do is visitor system, self-help registration login, CPPM OS is 6.2;
    Aruba Clearpass Guide 6.2,Most of the time, I studied not very compact configuration;
    1.CISCO Controller has been set up completed;( L3 authencaion ---captive Portal )
    2. I try to set up NAS on CPPM
    3.I try to set up Self-register configure (NAS, redirect page)
    4.What do I have to do? authorization profile ?  Mac Authencation ?
    5.I can successfully create account, But account is invalid,The default Policy I didn't move
  • 8.  RE: About Aruba ClearPass Guest configure ,Please Help me , Thanks!
    Posted Dec 14, 2013 12:27 AM
    Make sure you have COA enabled
