Wired Intelligent Edge
About BPDU protection feature
  • 1.  About BPDU protection feature
    Posted Apr 17, 2018 05:26 PM
    Hi experts,
    I have two doubts about this feature:
    1. I saw the BPDU protection feature is enabled on a per-port basis with the command "spanning-tree <port-list> bpdu-protection". Cisco has the command "spanning-tree portfast bpduguard" which allows to enable the feature in all the portfast ports at the same time. Is there any command to enable this feature in all auto-edge ports at the same time in Aruba?
    2. When this feature is enabled, is the port disabled always it receives a BPDU or only when it receives a better BPDU?
    Julián
  • 2.  RE: About BPDU protection feature
    Posted Apr 17, 2018 05:39 PM
    Greetings!
    Addressing your questions in order:
    1. ArubaOS-Switch allows configuration of BPDU protection on a per-port basis only; we do not have an equivalent to the command you provided. I will provide feedback to engineering.
    2. BPDU protection will shut down a port if any BPDU is received.  To cause a port to shut down only when a superior BPDU is received, you would instead use the root guard feature, which is configured in a nearly identical manner to BPDU protection:
    switch(config)# spanning-tree <port-list> root-guard
  • 3.  RE: About BPDU protection feature
    Posted Apr 17, 2018 05:44 PM
    Hi Matthew,
    Many thanks, very clear :)
    Julián
  • 4.  RE: About BPDU protection feature
    Posted Feb 04, 2019 06:32 AM
    On Cisco switches it's possible to automatically recover using the errdisable command. Do Aruba have something similar?
    Best regards,
    Trond Hundstuen
  • 5.  RE: About BPDU protection feature
    Posted Feb 04, 2019 08:45 AM
    Hi Trond,
    This is from the User Guide:
    Re-enabling a port blocked by BPDU protection
    Ports disabled by BPDU Protection remain disabled unless BPDU
    Protection is removed from the switch or by configuring a nonzero BPDU protection timeout. For example, if you want to re-enable protected ports 60 seconds after receiving a BPDU, you would use this command:
    switch(config)#: spanning-tree bpdu-protection-timeout 60
    Julián
