I want to create new SSID with Captive portal authentication , how can i create in web ui ,thank you
Do you want to use the controller's internal captive portal or ClearPass ?
internal server ,can you send me a doc to do it thank you.
This should get you going :
http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Captive_Portal.php
http://www.arubanetworks.com/wp-content/uploads/AOS_GuestAcccess-AppNote.pdf
