Hello all,
I went through the different community article for IPM and I'm still getting confused how IPM works, hopefully, I can get a resolution in this discussion.
I'm using a Cisco switch to provide to power up a couple of AP-315.
from the controller side, I enabled IPM with the following priorities
IPM enabled (applied to a specific AP for testing)
show ap debug system-status ap-name B1F1AP01 | begin "Power Status"
Power Status
Item Value
Power Supply: POE-AF
LLDP Power: Successfully negotiated at 20.8W
Current Operational State: 2.4GHz radio: No restrictions, 5GHz radio: No restrictions (Overridden by LLDP)
IPM Disabled
Power Status
Item Value
Current Operational State: No restrictions (Overridden by LLDP)
as you can see I got the same results with/without IPM,
my question now is simple, how/when IPM will take effect?
Additional output from Switch side (overview about PoE budget)
SW_B1F1#show power inline
Available:1400(w) Used:1292(w) Remaining:108(w)
