About LIC-ENT bundle licenses
  • 1.  About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:16 AM
    Hi community,
    I have found in IRIS within Mobility Controller > ArubaOS tab the LIC-ENT license bundle which includes one each: LIC-AP, LIC-PEF, LIC-RFP, LIC-AW. The LIC-AW is for AirWave. I have 100 APs and 2 controllers.
    1. If I purchase the LIC-ENT license, will I get separate license keys which I will enter in the controller and license keys which I will enter in AirWave?
    2. If I want to manage both the APs and controllers from AirWave, shall I select 100 LIC-ENT Within Mobility Controller > ArubaOS tab and 2 LIC-AW AirWave licenses independently for the controllers? Because if I select 102 LIC-ENT I will waste two LIC-AP, LIC-PEF, LIC-RFP licenses.
    Am I correct?
    Julián
  • 2.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:35 AM
    You need 100 ENT for your APs and 2 AW for the controllers
    Get Outlook for iOS
  • 3.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:40 AM
    Hi Victor Fabian,
    Ok, then I will get 100 LIC-ENT licenses from the controller item and 2 LIC-AW from the AirWave Licenses item. About my first question am I correct?
    Julián
  • 4.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:47 AM
    In the HPE portal you will have the option to select the amount of licenses you want to activate for a particular controller
  • 5.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:52 AM
    Ok, but will I also have the option to activate the licenses for AirWave LIC-AW in the HPE Portal and then get the license keys which I enter in the AirWave server?
    Thanks for your interest,
    Julian
  • 6.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:56 AM
    When you log into the license portal to activate you will get individual codes for each of the function licenses as well as your airwave licenses.
  • 7.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:49 AM
    Enterprise license just makes ordering the licenses easier.  You will still have to add individual function licenses to the controller.
  • 8.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 10:59 AM
    Hi chadteal,
    Yes, I know that. The only confusion I have is with LIC-ENT you have licenses for the controller and licenses for AirWave, and I want to be sure and I guess when I purchase this type of license I will get separate license keys for the controllers and for AirWave.
    Julián
  • 9.  RE: About LIC-ENT bundle licenses
    Posted Aug 22, 2017 11:01 AM
    Hi chadteal,
    We crossed each other with our replies. Ok, all clear.
    Thanks chadteal and Victor Fabian.
    Julián
