About securelogin.arubanetworks.com with http
This thread has been viewed 56 times
  • 1.  About securelogin.arubanetworks.com with http
    Posted Dec 26, 2021 10:58 PM
    I've a problem when using Windows 10 to access Aruba IAP Guest captive portal. At windows browser (Edge), I stuck on page https://securelogin.arubanetworks.com. If I changed the https to http at address bar, I can proceed. Can anyone suggest to change https to http://securelogin.arubanetworks.com?  Or if any better choice, please.
    Note: when using Macbook or Android phone, there are no any issues.
    Thanks.
    Sarawut
  • 2.  RE: About securelogin.arubanetworks.com with http
    Posted Dec 27, 2021 01:49 AM
    I was having similar issues. I solved it by going into Settings -> Privacy, Search, and Services -> Secure DNS.
    In my case, it was on, and I turned it off.
    Ledell Green
  • 3.  RE: About securelogin.arubanetworks.com with http
    Posted Jan 04, 2022 05:02 AM
    You should replace the securelogin.arubanetworks.com certificate with your own trusted certificate for Guest captive portal. Check here.
