About WEBAUTH Service and OnGuard Agent
  • 1.  About WEBAUTH Service and OnGuard Agent
    Posted Jul 19, 2017 04:02 PM
    Hi experts,
    Some days ago I was testing the OnGuard Application of ClearPass. I configured a WebAuth service to check the health of Windows computers when connected to corporate network 1. I installed the OnGuard Persistent Agent manually on the computer via http://<clearpass-ip>/agent/installer/windows/ClearPassOnGuardInstall.exe.
    The Health Check worked properly. But now when I turn on the Windows computer I get a WEBAUTH service rejected in ClearPass, though the computer is connected to corporate network 2 (although there is still IP connectivity between ClearPass and the computer):
    When connected to corporate network 1 the service works as expected:
    I don't want to use the OnGuard feature anymore, how can I get rid of the WEBAUTH service rejected? Is the only way removing the OnGuard Agent off the computer?
    Julián
  • 2.  RE: About WEBAUTH Service and OnGuard Agent
    Posted Jul 19, 2017 04:03 PM
    Yes, you would need to remove OnGuard from the client.
  • 3.  RE: About WEBAUTH Service and OnGuard Agent
    Posted Jul 19, 2017 04:14 PM
    Hi Tim,
    Just for curiosity, a couple of questions about this:
    1. Then, what if I want to use the Health Check for computers only when connecting to corporate network 1? When some of then connect to corporate network 2 I will get the rejections on ClearPass.
    2. How does the OnGuard Agent on the computer know the ClearPass IP address where to send the health check status?
    Julián
  • 4.  RE: About WEBAUTH Service and OnGuard Agent
    Posted Jul 19, 2017 04:22 PM
    Block TCP 6658 on network number 2 so it can't communicate with ClearPass.
    The IP/FQDN of ClearPass is part of the OnGuard installer.
  • 5.  RE: About WEBAUTH Service and OnGuard Agent
    Posted Jul 19, 2017 04:24 PM
    OK, thanks a lot!
    Julián
