AC3600 AP flag S
  • 1.  AC3600 AP flag S
    Posted Feb 26, 2019 02:45 AM
    Hi everyone,
    We are encounting a strange problem.
    Some Aps' flags suddenly have an "S" , then the SSID suddenly gone.
    After a while , flag "S" disappear and the SSID recover
    here are some output:
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    AP-003 AFW7 RAP-108 10.80.99.122 Up 16d:5h:36m:2s  S 10.80.99.231 10.80.99.232
    AP-004 AFW7 RAP-108 10.80.99.142 Up 16d:4h:49m:53s S 10.80.99.232 10.80.99.231
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
    I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
    X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
    c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
    i = Indoor; o = Outdoor
    M = Mesh node; Y = Mesh Recovery
    How can I fix this problem?
    Thank you for any answers
  • 2.  RE: AC3600 AP flag S
    Posted Feb 26, 2019 03:16 AM
    Have you turned on and checked the ap debug log already?
    Does the ssid disapear from "show ap bss-table" ?
  • 3.  RE: AC3600 AP flag S
    MVP EXPERT
    Posted Feb 26, 2019 08:54 AM
    The "S" flag will appear when an AP has made a standby GRE connection to another controller. Have you got HA failover enabled and do you have a BLMS IP specified in the AP System Profile?
    The AP is potentially failing over to a standby controller which does not have the correct configuration for the SSID/VAP (check it with #show profile-errors) so the SSID may not be broadcast.
