Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Accept as Solution!
  • 1.  Accept as Solution!
    Posted Jan 09, 2012 05:15 PM
    Did something you read in the Community solve a problem for you?  If so, click "Accept as Solution" in the bottom right hand corner of the post.
    This will let others in the Community know that a problem has been solved and others can benefit from the answer as well.
    To learn more about accepted solutions click here: http://community.arubanetworks.com/t5/help/faqpage/faq-category-id/solutions#solutions
  • 2.  RE: Accept as Solution!
    Posted Nov 09, 2018 02:12 PM
    How to go back to unsolve if did by mistake or accepted as solution by mistake?
  • 3.  RE: Accept as Solution!
    Posted Nov 10, 2018 08:27 PM
    Hi Nick IT,
    To unmark a solution, go to the post and click the ellipsis (3 dots) at the upper right corner.  In the dropdown list, click "Not the solution."  This option is only visible if you are the person who originally marked the post as the solution.
