Hi all,
I did a mistake on an HPE 3600-48-PoE+ v2 and I lost any access to modify configuration.
I was trying to enable SSH access with admin rights and secure console ports, but finally I just lost ability to change configuration since I saved the configuration before testing (dumb I am).
Bellow are the main part of the configuration, including the Comware version.
# version 5.20.99, Release 2111
domain default enable system
undo ip http enable
password-recovery enable
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
local-user admin
password cipher <masked>
authorization-attribute user-role network-admin
service-type ssh terminal
interface NULL0
ssh server enable
user-interface aux 0
user-role network-admin authentication-mode scheme
user-interface vty 0 15
protocol inbound ssh
save force
In striked blue the lines that did not worked (wrong/invalid commands) and that were supposed to grant admin account the relevant rights.
In red the lines that I suspect they made me lose the admin control of the switch.
Now when I connect via console port or SSH I can login with admin account but without any other access than display current configuration, I am not able to switch to system view.
Any help would be much appreciated on:
- How to gain back administrative rights (system view) or restore factory / previous configuration
- How to configure properly access (which commands instead of blue ones) ; should I create user role network-admin or use another role name?
Many thanks in advance,
Julien
