Access Point 224 AC
  • 1.  Access Point 224 AC
    Posted Jan 10, 2014 06:32 PM
    Hello, I can integrate the antena (ANT-2X2-5314) in Access Point AP-224AC?
    Please, i need help me
    Thanks!
  • 2.  RE: Access Point 224 AC
    Posted Jan 10, 2014 08:23 PM
    The following are the recommended antennas for the 224 (from the ordering guide: http://www.arubanetworks.com/pdf/products/OG_AP-220.pdf)
    Although other antennas may work with adapters; the ANT-2x2-5314 kit is only a 5GHz antenna; and the connector type is N-type x 2.; however the 224 is RP-SMA x 3.  Unless somone has additional suggestions, I don't think it is a good match.
  • 3.  RE: Access Point 224 AC
    Posted Jan 10, 2014 09:04 PM
    Thanks!
    Is possible install antennas the other vendor?
    I need external antennas with the following characterized:
    Band: 5.1 GHZ - 5.8GHZ
    Type: Direccional
    Gain: 14 dbi
    Polarization: horizontal
    Degress: 60°
    N-TYPE: Outdoor.
    Thanks!!
  • 4.  RE: Access Point 224 AC
    Posted Jan 13, 2014 08:16 AM
    The AP-ANT-93 is probably what you want, though it only has 20 degree beamwidth in both vertical and horizontal.  You'll need the pigtail adapters as well to connect from N-type to RP-SMA.
  • 5.  RE: Access Point 224 AC
    Posted Jan 13, 2014 02:34 PM
    To use single band antennas with AP-220 you need to cable to diplexer then cable form diplexer to single band antennas.
    this part has been used by some customers to do this
    http://www.l-com.com/bandpass-filter-rf-splitter-diplexer-for-24-ghz-5-ghz-wireless-lan-systems
    Un used ports should be terminated with
    http://www.l-com.com/coaxial-0-6-ghz-rp-sma-plug-terminator-50-ohm
