last person joined: 8 hours ago
Access Point Down When no Controller Reachability
  • 1.  Access Point Down When no Controller Reachability
    Posted Jun 14, 2013 10:20 AM
    I don't want AP to go down when no controller rechability ...
    is this doable @ both AP or RAP ?
    How ?
  • 2.  RE: Access Point Down When no Controller Reachability
    Posted Jun 14, 2013 10:23 AM
    This is not do-able with a Campus AP (CAP).  It is possible with RAP and Instant APs.  Any controller based AP will require controller connectivity to serve clients.
  • 3.  RE: Access Point Down When no Controller Reachability
    Posted Jun 14, 2013 11:06 AM
    i can see my RAP is down if controller is down
  • 4.  RE: Access Point Down When no Controller Reachability
    Posted Jun 15, 2013 12:28 PM
    RAPs typically run in Tunnel Mode (default) or Split-Tunnel.  In this mode they must talk to the controller.  They can also run in Bridge Mode and the SSID can be set to stay up even after the controller connectivity is lost.  There are trade-offs as some features are lost when running in bridge mode.   Be sure to read the Users Guide for a description of the different options in Bridge Mode (persistent, always, and backup modes).
  • 5.  RE: Access Point Down When no Controller Reachability
    Posted Jun 17, 2013 02:42 AM
    You should configure your AP as RAP to work without controller,
    The forwarding mode should be bridge and operation mode could be always persistence or back up as per your requirement
