Access Point Ethernet Port Speed Display
  • 1.  Access Point Ethernet Port Speed Display
    Posted Jan 08, 2014 08:54 AM
    Is there anywhere in the GUI that you can see the port configurations of the Access Points?
    Not the policy that sets the speed as such but the current speed an access point is running at present?
  • 2.  RE: Access Point Ethernet Port Speed Display
    Posted Jan 08, 2014 01:41 PM
    I am not aware of anything in the GUI, but you can run the following command to see it from the CLI:
    show ap port status ap-name <nameofAP>
    You can also use bssid, ip-addr, ip6-addr, or wired-mac instead of ap-name
    Sample Output:
    AP "00:0b:86:cf:80:89" Port Status (updated every 60 seconds)
    Port  MAC                Type  Forward Mode  Admin    Oper  Speed   Duplex  802.3az  PoE  STP  TX-Packets  TX-Bytes  RX-Packets  RX-Bytes
    0     00:0b:86:cf:80:89  GE    N/A           enabled  up    1 Gb/s  full    N/A      N/A  N/A  14602       2604693   49887       5566678
  • 3.  RE: Access Point Ethernet Port Speed Display
    Posted Jan 09, 2014 03:55 AM
    hmm that command doesnt exist in my version, 6.1.2.5.
    I assume I need a later version?
  • 4.  RE: Access Point Ethernet Port Speed Display
    Posted Jan 09, 2014 06:18 AM
    Yes, it was introduced in 6.2.   You can try Constantin's suggestion as well.
  • 5.  RE: Access Point Ethernet Port Speed Display
    Posted Jan 09, 2014 05:16 AM
    Another command introduced with Aruba OS 3.0 is : show ap debug system-status ap-name <the AP name>
    at the end of the output you would find somethign like :
    Ethernet Duplex/Speed Settings
    Autoneg Speed (Mbps) Duplex Iface
    on 100 Full bond0"
    Keep in mind that this command is to show the status of the Ethernet negotiation.
