Does anybody have a recommendation for an access point or access point/antenna combination for a log flat signal propagation? Normally I would use an access point with integrated 6 dBi omni-directional antennas (the mounting location is in the centre of the required coverage area) but I can't find an Aruba equivalent in the access point specifications and antenna matrix.
The coverage area is only approximately 30 metres squared but there are five portable offices in the coverage area. Hence why I need a long flat signal propagation.
I tested with an IAP105 and the coverage was marginal at the edges of the required coverage area. The IAP135 has integrated downtilt antennas so will not be suitable. I was looking at the IAP134 but I can't find a 6 dBi omni-directional antenna. There are 6 dBi sector antennas but I don't think I could mount the IAP134 with sector antennas at one end of the required coverage area and provide appropriate signal levels at the other end, particularly with the five portable offices.
