Access point IAP-104 to AP-104
  • 1.  Access point IAP-104 to AP-104
    Posted Feb 13, 2014 06:49 PM
    can we convert IAP-104 to AP-104 and vise verse ? Does it requie console access to do it. How can it find controller if converted to AP.
  • 2.  RE: Access point IAP-104 to AP-104
    Posted Feb 13, 2014 06:52 PM
    You can convert the IAP to a regular campus AP inside the IAP GUI by going to Maintenance > Convert. You can input the master controller address. The AP will also use the normal master discovery methods like DHCP option 43, aruba-master hostname and ADP.
    To convert the AP back to an IAP, you need to physically reset the AP with the reset button.
  • 3.  RE: Access point IAP-104 to AP-104
    Posted Feb 13, 2014 07:24 PM
    Tim there is no reset button on the 104, thats the rap3 or RAP155 as far i know!
    You will need to consle the AP and do this on the apboot
    To enter on the apboot
    Have the AP 104, connect the console cable to the AP and then power it up
    And then press enter  until you see the apboot
    on the ap boot issue this command
    clear os
    purge env
    save env
    reset
    And there you go you will have your ap back to IAP mode!
    Cheers
    Carlos
  • 4.  RE: Access point IAP-104 to AP-104
    Posted Feb 13, 2014 07:26 PM
    Ah, good catch. Was thinking of the 105.
  • 5.  RE: Access point IAP-104 to AP-104
    Posted Feb 13, 2014 07:27 PM
    But the 105 also does not have any reset button unless im missing it! =(
    I do know that RAP 155 do have it and also the rap3 becasue i have seen it! and there is no console por on either of thos APS as well.
    Cheers
    Carlos
  • 6.  RE: Access point IAP-104 to AP-104
    Posted Feb 13, 2014 07:29 PM
    My IAP-105 has one. It's not labeled, but it's there.
  • 7.  RE: Access point IAP-104 to AP-104
    Posted Feb 13, 2014 07:30 PM
    Like i said unless im missing it!!!! and i was missing it!
    Guess 104 will have the same button then my bad! sorry Tim you wer right the whole time! :)
  • 8.  RE: Access point IAP-104 to AP-104
    Posted Feb 14, 2014 09:24 AM
    All IAP models should have a reset button so you can convert back to IAP mode.
    I know the 115 and 135 have it and 225
