when you have mixed mode of Access Point like AP-61, AP-121 and AP-105, you need to see the client requirement and configuration details of Wireless Network Point.
so you need to segregate the Access point in Floor wise and had to install
I'm not sure I understand your question. Are you asking whether you need to separate different access points onto different floors? This is not necessary however if you mix dual radio access points like the AP105 and single radio access points like the AP61 that does not support 11n you will get patchy coverage with certain devices as you will not have dual radio uniform coverage. If I have completely missed your point please rephrase the question.
Mark
thanks for the post. the problem got resolved
