Access Point not registering Wireless Controller
  • 1.  Access Point not registering Wireless Controller
    Posted Dec 20, 2014 12:13 PM
    Dear All,
    Hope you all are doing well...
    I have Dell PowerConnect W-7210 Wireless LAN controller (it was Aruba now become dell) and Model: AP-103 I was trying to register my Access point in Wireless LAN controller unfortunately I cannot able to register my Access point in Controller. I can able to ping from controller to network switch ,switch to Access point and from Wireless Controller to Access Point
    Kindly please guide me for solving the issue bcz I am new in Aruba networks..
    Waiting for the reply
    Regards
    Muhammed
  • 2.  RE: Access Point not registering Wireless Controller
    Posted Dec 20, 2014 12:19 PM
    Try running show log system 50 on the controller and see if there are any errors.
    Also, try to console into the AP and watch the boot process. It should tell you why it's failing.
    Tim
  • 3.  RE: Access Point not registering Wireless Controller
    Posted Dec 20, 2014 02:40 PM
    Thank I will try
  • 4.  RE: Access Point not registering Wireless Controller
    Posted Dec 21, 2014 03:47 AM
    Dear All,
    Kindly please check the attached my Controller document
    Show loggin and version details..
    Waiting for your reply
    regards
    Muhammed Shafi
    Attachment(s)
    txt
    Sh-Version.txt   5 KB 1 version
    txt
    Boot-WLC.txt   6 KB 1 version
  • 5.  RE: Access Point not registering Wireless Controller
    Posted Dec 20, 2014 01:41 PM
    Is this a dell access point or Aruba? These all run different versions of the Aruba code and are not compatible with each other. Also, what version of code are you running on the controller? The AP requires AOS 6.4.0.1 on the dell controller.
  • 6.  RE: Access Point not registering Wireless Controller
    Posted Dec 20, 2014 02:47 PM
    Thanks for all support
    This is aruba Access point Version and all will check and get back to you
  • 7.  RE: Access Point not registering Wireless Controller
    Posted Dec 21, 2014 10:01 PM
    Dear All
    I have attached all file kindly please check
  • 8.  RE: Access Point not registering Wireless Controller
    Posted Dec 22, 2014 06:08 AM
    muhammed,
    Your controller is running 6.3.1.5.  According to the AP-103 datasheet here:  http://www.arubanetworks.com/pdf/products/DS_AP103Series.pdf the minimum version of code necessary is 6.4.0.0.  Please upgrade to 6.4.0.0 and try again.
  • 9.  RE: Access Point not registering Wireless Controller
    Posted Dec 22, 2014 11:38 AM
    Thanks for helping me .
    I will check all command and let you know
    regards
    muhammed
