Access point not taking profile from the controller....Access Point already took IP from DHCP
  • 1.  Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 04:46 AM
    Aruba Controller 6000----Cisco Core Switch 6509E VSS-----Cisco Distribution Switch 3750X-----Cisco Access Switch 2960X----Aruba AP 135----User Attached, please find the topology. The link between the core switch and the master controller is switchport mode access The link between the core switch and the local controller is switchport mode trunk
    #AP135
  • 2.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 05:46 AM
  • 3.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 06:42 AM
    Hi cjoseph,
    Thanks for the reply. yes we are using DHCP option 43 and 60.
  • 4.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 06:45 AM
    What type of DHCP server are you using?
    You should plug a console cable into an access point and watch the boot to see if it is taking the option.
  • 5.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 06:56 AM
    Hi Colin,
    We are using "Windows Server 2008 R2 Enterprise (Service Pack 1)"
    Regarding the option in the boot, I dont know where to look
    Attached is the boot output from console of the AP. Please let me know wher to look.
    Thanks and regards,
    Attachment(s)
    txt
    AP Output.txt   20 KB 1 version
  • 6.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 07:00 AM
    The most important parts are here:
    Getting an IP address...
    10.0.32.11 255.255.255.0 10.0.32.1
    Running ADP...Done. Master is 192.168.66.7
    AP rebooted Sun Jun 22 13:04:11 UTC 2014; SAPD: Reboot requested by controller
    shutting down watchdog process (nanny will restart it)...
     If your controller is at 192.168.66.7, your DHCP option is working.  Next we need to SSH into the controller, get into enable mode and find out why the access point is rebooting.  SSH into the controller and type "show log system 50" and type "show ap database" to see if you see any flags on that access point.
  • 7.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 07:31 AM
    Hi Colin,
    Actually,
    IP address of AP = 10.0.32.11
    IP address of Master Controller = 192.168.66.5
    IP address of Local Controller = 192.168.66.7
    Attached, please find the output of the "show log system 50" commands on both local and master controllers
    Thanks and regards,
    Attachment(s)
  • 8.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 07:37 AM
    Jun 22 11:39:56 :305051:  <WARN> |stm|  Virtual AP "6c:f3:7f:c2:cd:92" rejected for AP "AZ-IT-TEST"; reason: Forward mode requires Remote AP
     You have a Virtual AP (wireless network) configured in either bridge or split-tunnel mode.  Change it to tunnel, instead.
  • 9.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 07:39 AM
    For some reason its not attaching the file. I think the files are too big to get attached for the show ap database
    For the local controller the file size for the show ap database is 12.8 KB and
    For the master  controller the file size for the show ap database is 147 KB
    The AP is not showing on the local controller but its there in the master
    on the master controller, its showing,
    6c:f3:7f:c2:cd:92  AZ-IT-TEST                135      10.0.32.11   Down                     192.168.66.5   0.0.0.0
  • 10.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 08:04 AM
    Please take a look at my previous comment.
  • 11.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 11:10 AM
    Attached, please find the image. Its aleady in Tunnel mode.
  • 12.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 11:24 AM
    Does VLAN 132 exist on your local controller?
  • 13.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 04:12 PM
    Hi Colin,
    Yes, please c the attached files
  • 14.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 22, 2014 04:15 PM
    Are you sure that you don't have an ap-specific profile for that AP that is overriding the group setting?
  • 15.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 23, 2014 03:28 AM
    Hi Colin,
    No we don't have an ap-specific profile for any AP. Attached please find the screen shot
  • 16.  RE: Access point not taking profile from the controller....Access Point already took IP from DHCP
    Posted Jun 23, 2014 03:34 AM
    Please try to reprovision the AP into a separate ap-group when it comes up.
