Access Point shows down on master....up on local......
  • 1.  Access Point shows down on master....up on local......
    Posted Mar 21, 2013 11:35 AM
    I have some access points that aren't listed in the provisioning list on the master controller....but they are listed on the local and in airwave.......
    So I went to the command line and did a show ap database and the access points are in there but listed as down.
    But they are up...and serving clients....
    Any clues?
    Thanks in advance
  • 2.  RE: Access Point shows down on master....up on local......
    Posted Mar 21, 2013 12:02 PM
    If the local sees them as up and the master does not, confirm the local is talking to the master properly.
    show switches summary
  • 3.  RE: Access Point shows down on master....up on local......
    Posted Mar 22, 2013 09:52 PM
    Yea the controller is listed in there.
    I'm going to reboot it tonight and see if they all come back on the master.  Hopefully when I reboot the local they will failover to the backup local and the master can see them then.
  • 4.  RE: Access Point shows down on master....up on local......
    Posted Mar 22, 2013 11:38 PM
    What version of AOS are you running?
  • 5.  RE: Access Point shows down on master....up on local......
    Posted Mar 22, 2013 11:41 PM
    We are running 6.2.0.3...I think....sorry not connected now so can't look to the exact.
    At any rate, a reboot of the local cleared the issue up.
  • 6.  RE: Access Point shows down on master....up on local......
    Posted Mar 22, 2013 11:44 PM
    ok because according to the release notes for 6.2 there seems to be a bug regarding this
    bug id: 74074 Symptom: APs that are up and running on a local controller are listed as DOWN in the master's AP
    database.
