Access point without cabeling
  • 1.  Access point without cabeling
    Posted Nov 22, 2016 02:47 AM
    I have ground and first floor with fibre connection (Modem) on first floor.
    and i am unable to get proper signal on the ground floor and in my garden.
    Is there any solution in aruba so that i can deploy accespoints in my first floor, ground floor and outdoor access point in  my garden... WITHOUT ANY CABELING FOR APS/ IAP
  • 2.  RE: Access point without cabeling
    Posted Nov 22, 2016 04:43 AM
    I don't believe so, you will need to run a cable from the modem to the AP.
  • 3.  RE: Access point without cabeling
    Posted Nov 22, 2016 06:15 AM
    If you have power on the ground floor, you can attempt to use mesh.
  • 4.  RE: Access point without cabeling
    Posted Nov 22, 2016 10:41 AM
    Yes. I have power supplies in the ground floors and garden areas to powerup the IAP.
    So I can use IAP 205 oe iap 315... using this wireless mesh feature.
  • 5.  RE: Access point without cabeling
    Posted Nov 24, 2016 03:50 AM
    what are the things i have to take care of... while doing a site survey like
    Howmuch should be the distance between IAPs and
    How much signal strength is preferred at the place of second IAP to catch the signal from first IAP?
    and any other recommendations???
