Access Points 325
This thread has been viewed 40 times
  • 1.  Access Points 325
    Posted Oct 08, 2019 08:31 AM
    Hey all,
    i have a trouble with AP 325 Aruba, the AP are steel booting and I can't reset to factory, in the partion i have 0 no os the other partion 1 i have the OS
    apboot> os
    Partition 0 does not contain a valid OS image
    Partition 1:
    image type: 0
    machine type: 40
    version: 6.4.4.0-wave2
    build string: ArubaOS version 6.4.4.0-wave2 for 32x (p4build@cyprus) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #49847 SMP Thu Apr 30 14:49:32 PDT 2015
    flags: preserve factory
    oem: aruba
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    i boot it in the partion 1 but steel can't reset it
    i read in the forum that i need to change OS because there is a bug in this version: 6.4.4.0-wave2, i can't download the os somme one can help me please
    when the AP boot, it stop in this stat and reboot
    Getting an IP address...
    [ 40.157950] Kernel watchdog refresh ended on core 0.
    [ 40.277944] Kernel watchdog refresh ended on core 1.
    [ 40.722149] eth0: 100Mbps FullDuplex
    [ 40.998000] bonding: bond0: link status definitely up for interface eth0, 100 Mbps full duplex.
    [ 41.091783] bonding: bond0: making interface eth0 the new active one.
    [ 41.170071] bonding: bond0: first active interface up!
    [ 41.230459] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    10.10.10.2 255.255.255.0
    Running ADP...
    thank you for your help
  • 2.  RE: Access Points 325
    Posted Oct 08, 2019 08:46 AM
    The boot log does not show the AP finding its master.
    Who is the master controller for this AP?
    How is the AP set up to discover the master controller?
  • 3.  RE: Access Points 325
    Posted Oct 08, 2019 08:56 AM
    Thank's for the unswer
    I don't have the master how  can i do if i don't
    I have only one AP, because I recovered it to deploy it in another place, i can't get the controler
  • 4.  RE: Access Points 325
    Posted Oct 08, 2019 09:21 AM
    Hi community
    Please someone have an idea how to reset it.
    thank you
  • 5.  RE: Access Points 325
    Posted Oct 08, 2019 11:13 AM
    If you have a single AP, the model number on the sticker must say IAP-325, otherwise it cannot operate by itself.  You would need a separate hardware controller to work with an AP-325.
  • 6.  RE: Access Points 325
    Posted Oct 08, 2019 12:49 PM
  • 7.  RE: Access Points 325
    Posted Oct 08, 2019 12:53 PM
    https://community.arubanetworks.com/t5/Controller-less-WLANs/Where-is-the-reset-button-on-the-IAP-and-how-do-I-reset-the-IAP/ta-p/180980
    Right now it's an APusing ArubaOS 6.4.0.0
    If you are unsure whether it's an AP or IAP, hard reset the AP.
    If it is an IAP variant , it should come back up as an IAP.
  • 8.  RE: Access Points 325
    Posted Oct 08, 2019 12:55 PM
    This is an AP only variant.
    It says ap325 from the image shared. Also it's model is APIN 0325.Thus it needs a controller for it to come up.
  • 9.  RE: Access Points 325
    Posted Oct 09, 2019 08:31 AM
    Hey all
    Thank you so much for the answer, how can i do now if i want to get the controleur, i read in the net i can use AirWave with VM  to controle my AP 325, my question is how to download this for free and where i can download it, i buy this AP 325 very expensive for me
  • 10.  RE: Access Points 325
    Posted Oct 09, 2019 08:46 AM
    What is your requirement for the network?
    A controller based AP also requires a license bundle to be purchased additionally for the AP to be used whether it is virtual or hardware based controller.
    To use airwave to control the AP , You would first need a standalone MM setup or a MM-MD setup with SNMP&SSH enabled to the airwave server, this just calls for more licenses (MM-VA, MC-VA).
    If you just want a wifi device that you can plug a ethernet cable with internet access to and get started, then i'd say swap the AP to an IAP Variant.
  • 11.  RE: Access Points 325
    Posted Oct 09, 2019 08:57 AM
    hey  my requirement is juste one access point that i can broadcast one ssid, with my AP 325 i cannot configure that because th AP need a controler, before i work with IAP 515  and  IAP 315 those categorie does't need a controleur and i can easly create, but with AP325 i can't do anything,
    can i swap the AP to an IAP for this same physical model , because i just want a wifi devide that i plug a ethenet cable with internet access .
    thank's
  • 12.  RE: Access Points 325
    Posted Oct 09, 2019 09:46 AM
    If that is your requirement then an IAP is a better way to go.
    Contact your reseller/partner and enquire about changing the AP to an IAP.
  • 13.  RE: Access Points 325
    Posted Jan 09, 2021 11:16 AM
    I have the same access point with the same firmware  ArubaOS version 6.4.4.0-wave2 for 32x (p4build@cyprus) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #49847 SMP Thu Apr 30 14:49:32 PDT 2015
       I connect it to the controller 8.6.0.4, the AP downloads the firmware and goes into reboot, after rebooting, when I try to adopt, I get an error: Сan not reprovision AP with older image until it upgrades. and every 2 to 3 minutes downloads the firmware and  keep on reboot
    how to update the AP?
    Dmitriy Dmitriy
  • 14.  RE: Access Points 325
    Dmitriy Dmitriy
