Access Points Arm History Flag E issue?
  • 1.  Access Points Arm History Flag E issue?
    Posted Jan 29, 2015 10:54 AM
    Dears I have issues in some access points that its arm history show E flags for all changes happen kindly advice what is this issue?
  • 2.  RE: Access Points Arm History Flag E issue?
    Posted Jan 29, 2015 10:58 AM
    That means errors on the channel reached the ARM Error Threshold, so the access points changed channel.  In the short term, you can prevent this by raising the ARM Error Threshold from 50 to 90%:
    You might also want to open a TAC case to determine if the errors are real and if the threshold numbers should be adjusted further.
  • 3.  RE: Access Points Arm History Flag E issue?
    Posted Jan 29, 2015 11:15 AM
    Thank you will take this action
