Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
This thread has been viewed 66 times
  • 1.  Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 18, 2023 02:24 AM
    Hi all
    I have an issue on ArubaOS 8.10.0.6 LSR_86193 that the access points are not balancing across the our two controllers.
    Our two controlers are configured on the same layer 2 network.
    My normal go to for troubleshooting is:
    #show lc-cluster vlan-probe status
    Cluster VLAN Probe Status
    Type IPv4 Address    REQ-SENT REQ-FAIL ACK-SENT ACK-FAIL REQ-RCVD ACK-RCVD VLAN_FAIL CONN-TYPE START/STOP
    peer   10.10.10.31         3        0        4        0        4        3         0   L2 Conn     3/   3
    Normally there is a vlan_fail count.  In this case everything looks good.
    Redundancy:Yes
    Active Client Rebalance Threshold:20%
    Standby Client Rebalance Threshold:40%
    Unbalance Threshold:5%
    Active AP Load Balancing:YES
    Active AP Rebalance Threshold:20%
    Active AP Unbalanced Threshold:5%
    Active AP Rebalance Count:50
    Active AP Rebalance Timer:5 mins
    show lc-cluster load distribution ap
    Cluster Load Distribution for APs
    Type IPv4 Address    Active APs     Standby APs
    peer   10.10.10.31            102               0
    self     10.10.10.33            0             102
    Total: Active APs 102 Standby APs 102
  • 2.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 19, 2023 12:37 PM
    How long has this system been running?
    What controller model do you have?
  • 3.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 01:52 PM
    Check which controller is the leader in the cluster. Did you do a cluster upgrade or a manual upgrade? Did you manually move the AP's to the controller that is not the leader of the cluster?
  • 4.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 05:26 AM
    Maybe stupid question, but do you have a Mobility Conductor (MM) in place for these controllers?
    That is a requirement for load balancing as far as I know.
  • 5.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 05:32 AM
    There would not be any output to that command if an MM was not in place.
  • 6.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:02 AM
    It's like Herman state, you must have Conductors,
    but also equal amount off licensing, otherwise it will not balance (eg. 50/50)
    Steinar
  • 7.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:09 AM
    What is "equal" in a system that has an MM?  The licensing is shared and each access point gets a license.  If there was not enough licensing, access points would not come up.
    This user should let the controllers sit for awhile and allow it to balance.  Balancing can be gradual and is based on the capacity of the controllers.  It can be made more aggressive in the cluster config, but the most prudent thing is to wait.
  • 8.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:20 AM
    If you have one controller out of the box, you have 500 licenses,
    and one with a silver/[gold] license off 1000/[2000], it balance 500/1000[2000].
    (You do the maths for your environment)
    Steinar
  • 9.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:24 AM
    Understood.
    We should let the op respond to see if that is their setup.
  • 10.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:31 AM
    Hi
    we have 2 controllers and a pair of mobility masters.
    I am told that until the controller is 80% full (so I guess over 400 access points) it won't move any access points to the other.
    im sure that is different to how it was behaving in 8.6 - but I'm probably not remembering things right.
  • 11.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:36 AM
    That not the case, it will load balance any number you have.
    You may want to check your cluster setting
    managed network>cluster>cluster-profile>Advanced
    eg. This works fine, 50/50
    Steinar
  • 12.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 06:45 AM
    Is that clients of access points?
    the balancing comment is what I got back from a support call today.
  • 13.  RE: Access Points not load balancing ArubaOS 8.10.0.6 LSR_86193
    Posted Mar 20, 2023 07:57 AM
    it will balance both ap's and clients, at same ratio
    Steinar
