Access Points running in low power mode
  • 1.  Access Points running in low power mode
    Posted Aug 28, 2018 02:05 PM
    Is there an airwave report or CLI command we can run to identify which AP's are running in low power mode? The deployment of AP's is too large to walk the sites.
  • 2.  RE: Access Points running in low power mode
    MVP EXPERT
    Posted Aug 29, 2018 04:32 AM
    I don't believe there is a global command that you can run, however you can run this per AP.
    (Aruba620) #show ap debug system-status ap-name AP225 | begin "Power Status"
    Power Status
    Operational State          POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    Current HW State           POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    LLDP Negotiated POE Power  0.0W
  • 3.  RE: Access Points running in low power mode
    Posted Aug 29, 2018 10:11 AM
    we have over 4000 AP's to check. Nothing in Airwave? Maybe a log entry in the controller?
  • 4.  RE: Access Points running in low power mode
    Posted Aug 31, 2018 12:38 PM
    I haven't found anything in AirWave that grabs that field.  Looks like a good time to file a feature request.
