Access tacacs+ in clearpass
  • 1.  Access tacacs+ in clearpass
    Posted Apr 04, 2014 02:23 AM
    I can set access tacacs in clearpass?
    as configured?
  • 2.  RE: Access tacacs+ in clearpass
    Posted Apr 04, 2014 03:46 AM
    Can you expand upon your question please?
    It isn't clear what you're trying to achieve. Can you be more specific?
  • 3.  RE: Access tacacs+ in clearpass
    Posted Apr 04, 2014 06:37 PM
    i can configure tacacs access for ClearPass?
  • 4.  RE: Access tacacs+ in clearpass
    Posted Apr 04, 2014 07:33 PM
    Yes
  • 5.  RE: Access tacacs+ in clearpass
    Posted Apr 04, 2014 07:54 PM
    how configure in ClearPass? some guide?
  • 6.  RE: Access tacacs+ in clearpass
  • 7.  RE: Access tacacs+ in clearpass
    Posted Apr 05, 2014 06:49 AM
    I do not want ClearPass of tacacs server. I want to configure tacacs access (ACS) by ClearPass
  • 8.  RE: Access tacacs+ in clearpass
    Posted Apr 08, 2014 05:11 AM
    I think you're asking if you can set administrative logins into Clearpass to be authenticated via an external TACACs server correct?
    If so, no I don't believe there's a way to do that (unless one of the other guys knows differently).
    What you could try, is validating administrative connections into Clearpass via a RADIUS proxy. Cisco ACS (if that's what you're using) acts as a standard RADIUS too (unless you've turned it off), so that might work. Never tried it. If I was going to, I'd...
    Setup a proxy...
    Configuration > Network > Proxy Target
    Then define a service that uses the proxy, but otherwise looks like the "Policy Manager Admin Network Login Service" service.
    This might break it if it didn't work, so try it in a lab first.
