access to IAP
  • 1.  access to IAP
    Posted Apr 27, 2012 08:20 AM
    i was wondering if it is possible to gain CLI access to the IAP in another way then the serial console port? so by SSH or telnet or such, is there a setting or isn't it possible?
  • 2.  RE: access to IAP
    Posted Apr 27, 2012 09:01 AM
    AFAIK, it is possible to use SSH to get into the IAP, but there is very little you can actually do once you are in (some show and debug commands).  All configuration should be done via the GUI.
  • 3.  RE: access to IAP
    Posted Apr 27, 2012 12:43 PM
    Access is via telnet which can be enabled on the UI. console access is also possible.
    However, as the previous response is correct - no support for CLI commands and recommendation is to use UI.
    thanks,
    Shashi
  • 4.  RE: access to IAP
    Posted Apr 27, 2012 01:35 PM
    thank you both.
    just for interest, where can the setting to turn on telnet be found?
  • 5.  RE: access to IAP
    Posted Apr 27, 2012 01:55 PM
    Under settings->terminal access
    Attached screen shot.
    thx
    Attachment(s)
    pptx
    terminalaccess.pptx   72 KB 1 version
  • 6.  RE: access to IAP
    Posted Apr 27, 2012 02:18 PM
    thanks, must have overlooked that one a couple of times.
