Access to Internet problem / airwave communication issue
  • 1.  Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 08:24 AM
    Hi Guys
    Hope everybody having good day
    I' have created 4 Vlan on the controller
    Vlan 2 : is edge vlan / uplink to internet (2.2.2.2/24) natoutside
    Vlan 7 : is vlan to private network (7.7.7.2/24) natinside
    Vlan 4: AP management (4.4.4.1/24) intervlan routing (Internal DHCP)
    Vlan 5 : User traffic (5.5.5.1/24) intervlan routing (Internal DHCP)
    * Getaway for the controller is on Vlan 2 (Ip Route .0.0.0/0 [0/1] via 2.2.2.1*)
    * Controller Ip is still on the default vlan 172.16.0.254 * Vlan 3 is private network which airwave on it
    *  the communication between the private vlan through the firewall
    My question is :-
    * User on Vlan 5 can't access internet what is the issue
    * is it possible that the airwave and controller can communicate to each other through the private vlans
    i have attached simple diagram for more information
    Thank you in advance for the answers
  • 2.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 08:47 AM
    The default gateway on VLAN 5 is responsibie for delivering traffic to the internet.  What is that device?
  • 3.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 08:55 AM
    Vlan 5 is internal vlan on the controller , 5.5.5.1 the the ip of the interface vlan
    dhcp pool for vlan 5 is configured on the controller
  • 4.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 09:06 AM
    Clients on that VLAN will have access to the internet in two situations:
    "ip nat inside" or source nat is enabled on interface vlan 5 OR
    Your border firewall has a route pointing to the controller for subnet 5.5.5.x AND will allow 5.5.5.x traffic to go to the internet.
  • 5.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 09:23 AM
    my firewall has already static route to allow 5.5.5.x traffic to go through
  • 6.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 09:27 AM
    It needs a static route pointing at the controller's ip address for the 5.5.5.x subnet.
  • 7.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 09:41 AM
    that what is appear when i run show ip route
    Gateway of last resort is 2.2.2.1 to network 0.0.0.0 at cost 1
    S* 0.0.0.0/0 [0/1] via 2.2.2.1*
    C 172.16.0.0/24 is directly connected, VLAN1
    C 4.4.4.0/24 is directly connected, VLAN 4
    C 5.5.5.0/24 is directly connected, VLAN 5
    C 7.7.7.0/24 is directly connected, VLAN 7
    C 2.2.2.2.0/24 is directly connected, VLAN2
    i can't see why i need to add an ip route ?
    thanks
  • 8.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:12 AM
    No. The controller's default gateway should be the internet firewall. If the controller is the default gateway for the 5.5.5.x network, the firewall needs to know how to deliver packets coming back from the internet to that subnet, so the firewall needs a route for that subnet pointing to the IP address of the controller
  • 9.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:23 AM
    the firewall has this route already
  • 10.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:28 AM
    Ok. The firewall needs a route to the controller for the 5.5.5.x subnet. Do you have that in place?
  • 11.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:31 AM
    Yes i have , and i can see it network 5.5.5.0 routed to 2.2.2.2
  • 12.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:34 AM
    What is 2.2.2.2?
  • 13.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:38 AM
    So you have any basic networking functional? Can the controller ping internet addresses?
  • 14.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 11:39 AM
    it's aruba controller interface vlan 2 ip which is connected to fiewall interface on vlan 2
    2.2.2.2 >>> controller
    2.2.2.1 >> Fw
    2.2.2.1 is default getway for the controller
  • 15.  RE: Access to Internet problem / airwave communication issue
    Posted Jan 11, 2020 12:13 PM
    yes i can ping and traceroute public address
