Access Tracker Monitoring from Publisher
  • 1.  Access Tracker Monitoring from Publisher
    Posted Apr 04, 2018 05:08 AM
    Hi
    Curenntly i have a clearpass cluster with one publisher and 4 subscriber.
    as we know the access tracker and event view is stay in the subscriber. Let say i want to troubleshoot the client connectivity from access tracer but centralized from publisher, how can i do it?
    pub-sub communication is using http. 'Port 80 is used to render System Monitor data from a remote node. Can be modified using the cluster-wide parameter “Performance Monitor Rendering Port”
    thanks
  • 2.  RE: Access Tracker Monitoring from Publisher
    Posted Apr 04, 2018 05:47 AM
    In the publisher node, you can edit the filter of the Access Tracker and select the server or all servers, including subscriber nodes.Screen Shot 2018-04-04 at 11.46.06.png
  • 3.  RE: Access Tracker Monitoring from Publisher
    Posted Apr 04, 2018 05:49 AM
    thanks,
    thats means i can view the access tracer on the subscriber (other nodes) from publisher?
  • 4.  RE: Access Tracker Monitoring from Publisher
    Posted Apr 04, 2018 05:57 AM
    Ussually I don't configure it, but technically yes. I can't check it now. In the access tracker there's a column to show the server name, you could identify whats is the node that is doing these authentication.
  • 5.  RE: Access Tracker Monitoring from Publisher
    Posted Apr 04, 2018 10:27 PM
    thanks its worked perfectly
