Accessing HP 5412zl by console
  • 1.  Accessing HP 5412zl by console
    Posted Jun 10, 2017 07:52 AM
    I faced problem that i cannot access the switch by console because i dont Know the password , so how i can delete console password without loosing the configuration.and what is the default password .
    thanks..
  • 2.  RE: Accessing HP 5412zl by console
    Posted Jun 12, 2017 05:47 PM
    With a paperclip holding down the clear button for three seconds should be resetting the console password. This is only possible when the frontpanel buttons are not protected.
  • 3.  RE: Accessing HP 5412zl by console
    Posted Jun 15, 2017 03:10 AM
    can you tell me what is default username and password of this switch to access by console ?
  • 4.  RE: Accessing HP 5412zl by console
    Posted Jun 25, 2017 06:04 AM
    By default there is NO username and password, you should just get access to the console with full manager rights.
    If you used the 'setup' command for initial configuration, it asks for a password and will set that to the username: manager. So if you have a clue what password could be set, you might try that with username "manager".
    If you don't know the password, follow the reset procedure (that removes the configuration): http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=mmr_kc-0127335
    .. and you may need to wait 25 seconds instead of 5 for the 5412zl according to http://h20566.www2.hpe.com/hpsc/doc/public/display?sp4ts.oid=5179499&docLocale=en_US&docId=emr_na-c02597269
  • 5.  RE: Accessing HP 5412zl by console
    Posted Sep 03, 2020 10:10 AM
    I had the same issue with my new 5412zl switch. I tried resetting it to the factory default but it did not help either. Is there any other way to solve this problem?
