Accounting with Cisco switch
  • 1.  Accounting with Cisco switch
    Posted Jun 22, 2014 07:39 AM
    I m trying to test accounting between CPPM & Cisco.
    I m providing attribute Class in radius return to Switch. but once I check accounting on CPPM, I m not seeeing Class attribute from Switch.
    I have put all related aaa accounting commands and also radius vsa accounting command o Cisco. Switch ia 3750X and IOS is 15.0 SE.
    Any guide in this regard.
    #ALE
  • 2.  RE: Accounting with Cisco switch
    Posted Jun 22, 2014 01:30 PM
    start a packet capture to check if the swich actually sends the information.
  • 3.  RE: Accounting with Cisco switch
    Posted Jun 22, 2014 02:22 PM
    @atifj wrote:
    atifj,
    Radius accounting and Radius attributes are two different things.  Radius accounting would have to occur after successful authentication.  First things first....is authentication even happening?
  • 4.  RE: Accounting with Cisco switch
    Posted Jun 22, 2014 05:45 PM
    https://afp.arubanetworks.com/afp/index.php/Tacacs_command_authorization
    First, we configure the TACACS server on the Cisco box:
    Switch(config)# tacacs-server host 172.16.16.200 key aruba123 (Note that in some versions of IOS the key must be entered on a separate line of config: tacacs-server key aruba123)
    Next we setup AAA authentication:
    Switch(config)# aaa authentication default group tacacs+ local
    Switch(config)# aaa authentication enable default group tacacs+ enable
    This tells the switch that, for login attempts, to first look at TACACS, if that is unreachable, use the local database. When a user types "enable" to gain privileged mode access to first check TACACS and if that is unreachable, use the locally stored enable password or secret.
    Now we setup AAA authorization for commands:
    Switch(config)# aaa authorization commands 0 default group tacacs+ none
    Switch(config)# aaa authorization commands 1 default group tacacs+ none
    Switch(config)# aaa authorization commands 15 default group tacacs+ none
    This sends all commands entered at the privilege level 0, 1 and 15 to the configured TACACS server(CPPM) for authorization and failing that, it disallows the command.
    Levels 0, 1 and 15 map to the following:
    • level 0—Includes the disable, enable, exit, help, and logout commands
    • level 1—Includes all user-level commands at the router> prompt
    • level 15—Includes all enable-level commands at the router# prompt
    Lastly, if you want to audit Cisco config commands:
    Switch(config)# aaa authorization config-commands
    This instructs the switch to run all config level commands through tacacs for authorization.
    Be a good little Cisco admin:
    Switch(config)# exit
    Switch# write mem
  • 5.  RE: Accounting with Cisco switch
    Posted Jun 23, 2014 05:20 AM
    Authentication is successfully completing.
    My Scenario is that I am using Cisco Switch for dot1x authentication of PC connected to them.
    My Requirement is that I am sending Class attribute to Cisco Switch, Once PC authenticated with CPPM, I added CLASS attribute in VLAN enforcement so that PC get VLAN according to test and Class attribute and want that Class attribute back in Accounting packet.
    I am doing this to send accounting packets to Firewall so that if any user's traffic reach firewall without Authentication with CPPM, that Firewall blocks its traffic.
    Any Help.
    My Cisco Switch Configuration is:
    aaa new-model
    aaa authentication login VTY group radius local
    aaa authentication dot1x default group radius
    aaa authorization exec VTY group radius local
    aaa authorization network default group radius
    aaa authorization auth-proxy default group radius
    aaa accounting auth-proxy default start-stop group radius
    aaa accounting dot1x default start-stop group radius
    aaa accounting exec default start-stop group radius
    aaa server radius dynamic-author
     client 192.168.1.100 server-key XXXXX
    aaa session-id common
    radius-server attribute 6 on-for-login-auth
    radius-server attribute 6 support-multiple
    radius-server attribute 8 include-in-access-req
    radius-server attribute 25 access-request include
    radius-server dead-criteria time 5 tries 1
    radius-server host 192.68.1.100 auth-port 1645 acct-port 1646 key XXXXX
    radius-server deadtime 1
    radius-server vsa send accounting
    radius-server vsa send authentication
  • 6.  RE: Accounting with Cisco switch
    Posted Jun 23, 2014 02:39 PM
    sorry but i still don't quite understand what you are doing.
    My Requirement is that I am sending Class attribute to Cisco Switch.
    why exactly? after reading up on it i conclude this is something used between radius authorization and accounting, but there is no need to work with it yourself. do you have a specific need to work with it? are you sure accounting doesnt just work without manually manipulating the class?
    ok, even more confused now. what firewall?
    i come back to my original reply, use a packet sniffer to check the accounting records really aren't send.
