Accouting Aruba 7030 and CPPM
  • 1.  Accouting Aruba 7030 and CPPM
    Posted Dec 10, 2018 08:55 AM
    I have a fault with an Aruba 7030 controller and a CPPM, I have an SSID that authenticates by 802.1x, when the user is validated
    CPPM does not know the state of the user (I do not have the accounting) I tried to activate the option "RADIUS Interim Accounting"
    in the AAA Profile of the controller but the CPPM continues without saving the accounting.
    With wired 802.1x with switch Aruba working fine.
    I need this to send the Accouting to a Forigate firewall for RSSO.
    Thanks!
  • 2.  RE: Accouting Aruba 7030 and CPPM
    Posted Dec 10, 2018 09:42 AM
    Under the AAA profile there is a radius accounting server group that you need to put your radius accounting servers in. When you do that it will record radius starts and stops. Since you have radius interim accounting enabled, it will also send accounting statistics every 5 minutes.
  • 3.  RE: Accouting Aruba 7030 and CPPM
    Posted Dec 17, 2018 09:17 AM
    Thanks!!
    Working fine.
