ACE-Table Question
  • 1.  ACE-Table Question
    Posted Apr 04, 2016 12:20 PM
    Cisco ASA's refer to it as Service Object Groups.  These are named groups which "houses" a collection of preconfigured service objects.  "Service objects" are either tcp, udp, or tcp/udp groupings or ports on a 1:1 ratio.
    In Aruba's realm, we see service objects as  netservice names in which we can apend up to 6 ports.
    Does Aruba have something simular to the Service Object Groups where you can create a group name, and then reference multiple "service objects" underneath it?
    In the eyes of an ACE-Table, creating a group to call on a bunch of listed services could be beneficial and lower the ACE count cost, couldn't it?
    Lastly, is there a possibility to include multiple Port Ranges?  meaning,
    netservice my_netservice_name tcp 135 139, 15024 15124
  • 2.  RE: ACE-Table Question
    Posted Apr 04, 2016 02:46 PM
    There is nothing in Aruba that would allow multiple service objects to be applied as a group at this time.  You can however request that functionality on the Ideas Portal here:  https://sso.arubanetworks.com/idp/rp6Pf/resumeSAML20/idp/startSSO.ping
  • 3.  RE: ACE-Table Question
    Posted Apr 04, 2016 03:11 PM
    After looking through things, I didn't think there was -- thus the forum post.  :)
    Thank you sir.  Will be doing a request.
