ACL blocks UDP broadcast when specifying port
  • 1.  ACL blocks UDP broadcast when specifying port
    Posted Feb 28, 2013 06:48 AM
    Hi.
    I am setting up a ACL rule which says
    SRC: any DST: any Service TCP / UDP *port* permit
    This works as long as the server and client device communicates directly to each others IP address.
    The server uses UDP broadcast on the specified port to discover devices. This does not work.
    The client device "data-LED" shows some activity when the broadcast is sent, so it looks like the broadcast gets through.
    The server never recieves the response tough.
    if I change the ACL rule to say:
    SRC: any DST: any Service: Any permit, the broadcast discovery works.
    When I check the wireshark logs the only specified is the same port that I spesify in the rule.
    Anyone know what might cause this?
    Thanks!
  • 2.  RE: ACL blocks UDP broadcast when specifying port
    Posted Mar 05, 2013 10:39 PM
    Type "show acl hits" to see if your traffic is hitting the firewall policy.
  • 3.  RE: ACL blocks UDP broadcast when specifying port
    Posted Mar 06, 2013 07:36 AM
    Thanks.
    We just solved this case.
    Turned out that the equipment that the customer was using is work in progress, so the documentation was not complete.
    The broadcast was answered to the private/dynamic port that the broadcast was sent from. This way, the traffic was using a different destination port than what we defined in the acl. This was fixed so now everything works as expected :D
  • 4.  RE: ACL blocks UDP broadcast when specifying port
    Awesome.
