Wired Intelligent Edge
last person joined: 3 hours ago
ACL for communication between VLANs
  • 1.  ACL for communication between VLANs
    Posted May 25, 2020 05:45 PM
    Hello
    I have an aruba 2930F switch where I have created 3 vlan
    I want vlan 2 and vlan 3 to have full input and output communication with these vlan 1 addresses (192.168.1.71 and 192.168.1.79)
    #2930F
  • 2.  RE: ACL for communication between VLANs
    Posted Jun 07, 2020 03:41 AM
    can I know where the VLAN 2 & VLAN 3 gateway configured?
    If the gateways are configured on the same switch then all end will communicate using local and direct routes from the gateway?
    and if VLANs gateways are in different switches then required routing and ACL are required to configure.
    Best Regards,
    Suresh
