Comware
ACL On HPE 1920S JL386A
  • 1.  ACL On HPE 1920S JL386A
    Posted Oct 19, 2021 02:53 PM
    Good Afternoon
    I´m trying make a ACL on JL386A, where only 3 ip address, can access web management of switch. This situation is very simple on Comware versions 5 and 7. In this equipament we can´t enable ssh conection, and on configuration guide, do not have line paramenter, to write on configuration file.
    #Aruba
    #Switch_Router_Interconnect
  • 2.  RE: ACL On HPE 1920S JL386A
    Posted Oct 19, 2021 04:02 PM
    Hello @Fabio2,
    HPE OfficeConnect 1920S Switch series is Web Manageable only so there is no ssh feature.
    You can refer user guide supported features on pg.10.
    I am not sure if you are referring same guide for ACL. Kindly refer pg.143 for ACL configuration.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00003478en_us
    Or log a case with support so they will help you to configure ACL.
    Thanks!
