Comware
  • 1.  ACL Rule Fails When Logging Enabled on HP v1910-24G (Comware 5)
    Posted Dec 27, 2019 02:26 PM
    Hi everyone,
    I'm running into a problem enabling logging on one of my ACL rules. Specifically this rule:
    rule 30 deny ip destination 10.0.0.0 0.0.255.255 logging
    I have this ACL applied (packet-filter) to a Vlan-interface inbound.
    When the logging parameter is enabled, I get the following error:
    ACL_RULE_OTHER_ERROR - Error occurred in ACL 3010 rule 30.
    Or, if the ACL has not yet been applied to the Vlan-interface, I get the following error when I apply it with packet-filter:
    FLT_SET_POLICY_NOTSUPPORT_FAIL - Failed to apply the filter policy to or refresh the filter policy 3010:30 on interface Vlan-interface10.Not supported.
    I know this problem is specific to the logging argument because, when I remove it from the rule, everything functions just fine.
    However, for security/administrative purposes (in case I have accidentally blocked a legitimate connection), I really need logging available.
    Any idea what's going on and how I can fix this?
    Thank you in advance!
    #logging
    #1910
    #ACL
    #comware
  • 2.  RE: ACL Rule Fails When Logging Enabled on HP v1910-24G (Comware 5)
    Posted Jan 06, 2020 04:05 PM
    What version of code are you running?  The latest code is R1519P06.  This could be a resolved issue if your code is very old.
    Dav id
  • 3.  RE: ACL Rule Fails When Logging Enabled on HP v1910-24G (Comware 5)
    Posted Jan 09, 2020 08:32 PM
    Hi David,
    Thank you for the reply. I had considered the same thing. Unfortunately, I am currently running 1519P06.
    Any other ideas?
