ACLs - configure 'next-hop-list'. Where to define the next-hop
  • 1.  ACLs - configure 'next-hop-list'. Where to define the next-hop
    Posted Mar 29, 2014 09:01 AM
    Just looking at the session ACLs and there is an extended option for 'next-hop-list'.
    I can't seem to find where you can define this 'next-hop'.  It's almost as though the command has been depracated, but it is still mentioned in the 6.3 CLI Guide.
    Anyone used this option before?  I'd like to use it for some policy-based routing if possible.
  • 2.  RE: ACLs - configure 'next-hop-list'. Where to define the next-hop
    Posted Apr 28, 2014 05:27 AM
    update from TAC is the following.
    The latest update from engineering team is that this "policy based routing" feature has not been supported yet. The 'next-hop-list' option is a part of this feature. Currently the configuration option is preset but it does not do anything. This will be removed till the feature gets implemented completely.
